hatten heute das Problem das ein paar Millisekunden nach alarmeingang das Katsysplugin scheinbar gecrasht ist und dadurch kein Alarm angelegt wurde:
2023-04-26T09:26:19.038Z [info] PLGMANAGER [KATSYS] UNSOLICITED MESSAGE:
2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] katsys_error {}
Hier ein Screenshot des betroffenen Zeitraumes:
|2023-04-26T09:26:19.039Z [debug] PLGMANAGER [EVENTS] |BROADCAST | event_katsys_incoming_data|
|2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] |katsys_error {}|
|2023-04-26T09:26:19.047Z [info] PLGMANAGER [EVENTS] |Admin Notification: KATSYS Cloud Fehler: {}|
|2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] |Restart Service…|
|2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] |Kill Service…|
|2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] |Killing Service with SIGHUP…|
|2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] |Killed Service waiting 1s for Service restart…|
|2023-04-26T09:26:19.049Z [info] PLGMANAGER [KATSYS] |KATSYS Service EXITED. Exit Code: null|
|2023-04-26T09:26:20.047Z [debug] PLGMANAGER [KATSYS] |Using Parser: parserSAD|
|2023-04-26T09:26:20.048Z [info] PLGMANAGER [KATSYS] |Properly inititlized settings|
|2023-04-26T09:26:20.048Z [debug] PLGMANAGER [KATSYS] |initialized Plugin: true|
|2023-04-26T09:26:20.048Z [info] PLGMANAGER [KATSYS] |Starting Service|
|2023-04-26T09:26:20.055Z [info] PLGMANAGER [KATSYS] |Service started with pid 33166|
|2023-04-26T09:26:20.124Z [info] PLGMANAGER [KATSYS] |Recieved Configuration from CORE|
|2023-04-26T09:26:20.124Z [info] PLGMANAGER [KATSYS] |Starting connection to KatSys Cloud|
|2023-04-26T09:26:20.124Z [info] PLGMANAGER [KATSYS] |configuring Parser|
|2023-04-26T09:26:20.124Z [info] PLGMANAGER [KATSYS] |Using Parser ILSSAD|
|2023-04-26T09:26:20.174Z [info] PLGMANAGER [KATSYS] |Initialising WebSocket|
|2023-04-26T09:26:20.346Z [info] PLGMANAGER [KATSYS] |Connection Status has changed to true|
|2023-04-26T09:26:20.346Z [info] PLGMANAGER [EVENTS] |Admin Notification: KatSys ist nun verbunden|
|2023-04-26T09:26:20.347Z [info] PLGMANAGER [KATSYS] |Starting heartbeat check each 30 seconds|
|2023-04-26T09:26:20.347Z [info] PLGMANAGER [KATSYS] |Connection to KatSys Cloud opened|
|2023-04-26T09:26:20.347Z [info] PLGMANAGER [KATSYS] |UNSOLICITED MESSAGE: {logmessage : RAW: {type:info,msg:Verbindung aufgebaut,statusCode:connection_established,statusClass:success}}|
Gibt es eine Möglichkeit herauszufinden, was zu dem Absturz geführt hat?
Fehlermeldung wurde scheinbar keine mit ausgegeben:
| 2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] | katsys_error {} |
| 2023-04-26T09:26:19.047Z [info] PLGMANAGER [EVENTS] | Admin Notification: KATSYS Cloud Fehler: {} |
| 2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] | Restart Service… |
| 2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] | Kill Service… |
| 2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] | Killing Service with SIGHUP… |
| 2023-04-26T09:26:19.047Z [info] PLGMANAGER [KATSYS] | Killed Service waiting 1s for Service restart… |
| 2023-04-26T09:26:19.049Z [info] PLGMANAGER [KATSYS] | KATSYS Service EXITED. Exit Code: null |
Die Heartbeat checks vorher liefen auch ohne Probleme:
|2023-04-26T09:23:28.765Z [info] PLGMANAGER [KATSYS] |Heartbeat Check successful (2.354 | 2354)|
|2023-04-26T09:23:58.773Z [info] PLGMANAGER [KATSYS] |Heartbeat Check successful (12.363 | 12363)|
|2023-04-26T09:24:00.005Z [debug] PLGMANAGER [EVENTS] |BROADCAST | event_alarm_closed|
|2023-04-26T09:24:00.005Z [info] PLGMANAGER [WALLBOARD] |EVENT event_alarm_closed received|
|2023-04-26T09:24:28.776Z [info] PLGMANAGER [KATSYS] |Heartbeat Check successful (2.365 | 2365)|
|2023-04-26T09:24:58.789Z [info] PLGMANAGER [KATSYS] |Heartbeat Check successful (12.378 | 12378)|
|2023-04-26T09:25:28.792Z [info] PLGMANAGER [KATSYS] |Heartbeat Check successful (2.382 | 2382)|
|2023-04-26T09:25:58.805Z [info] PLGMANAGER [KATSYS] |Heartbeat Check successful (12.391 | 12391)|
|2023-04-26T09:26:00.006Z [debug] PLGMANAGER [EVENTS] |BROADCAST | event_alarm_closed|
Gruß Andi
